Hi ricmarques
Thank you for your reply, I have tried that and get the following:-
"Software index is broken
this is a major failure of your software management system. Pleas check for broken packages with synaptic, check the file permissions and correctness of the file /etc/apt/sources.list and reload the software information with sudo apt-get update and sudo apt-get install -f"
Synaptic will not run, just comes up with zoom needs to be reinstalled.
I have done the following from the terminal:-
sonyuser@SonyVaio:~$ cat /etc/apt/sources.list
newer versions of the distribution.
deb Index of /ubuntu jammy main restricted
deb-src Index of /ubuntu jammy multiverse restricted main universe
Major bug fix updates produced after the final release of the
distribution.
deb Index of /ubuntu jammy-updates main restricted
deb-src Index of /ubuntu jammy-updates multiverse restricted main universe
N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
team. Also, please note that software in universe WILL NOT receive any
review or updates from the Ubuntu security team.
deb Index of /ubuntu jammy universe
deb Index of /ubuntu jammy-updates universe
##deb-src Index of /ubuntu xenial-updates universe
team, and may not be under a free licence. Please satisfy yourself as to
your rights to use the software. Also, please note that software in
multiverse WILL NOT receive any review or updates from the Ubuntu
security team.
deb Index of /ubuntu jammy multiverse
deb Index of /ubuntu jammy-updates multiverse
##deb-src Index of /ubuntu xenial-updates multiverse
N.B. software from this repository may not have been tested as
extensively as that contained in the main release, although it includes
newer versions of some applications which may provide useful features.
Also, please note that software in backports WILL NOT receive any review
deb Index of /ubuntu jammy-security main restricted
deb-src Index of /ubuntu jammy-security multiverse restricted main universe
deb Index of /ubuntu jammy-security universe
##deb-src Index of /ubuntu xenial-security universe
deb Index of /ubuntu jammy-security multiverse
##deb-src Index of /ubuntu xenial-security multiverse
deb Index of /ubuntu jammy-security universe multiverse main restricted
sonyuser@SonyVaio:~$ sudo apt-get update
Hit:1 Index of /ubuntu jammy InRelease
Hit:2 Index of /ubuntu jammy-updates InRelease
Hit:3 Index of /ubuntu jammy-security InRelease
Ign:4 Index of /stable/deb/ stable InRelease
Hit:5 Index of /ubuntu jammy-security InRelease
Hit:6 Index of /stable/deb/ stable Release
Reading package lists... Done
sonyuser@SonyVaio:~$ sudo apt-get install -f
Building dependency tree... Done
E: The package zoom needs to be reinstalled, but an archive for it can't be found.
