Hi! This is mu current 16.04 desktop
https://postimg.org/image/hj7dzhmjr/
Where can i find the wallpaper?
I put the UM logo on it but it can be found without if you wish.
http://i67.photobucket.com/albums/h295/vtvbreech/sub_zpsxoibnnhu.jpg
Im new here so i thought this would be a nice way to introduce
Theme is Mint-Y Dark and icons are Faenza-dark
Nice. Did you manage to make the progress bar in some programs not appear white on active? I seem to have that problem while in Linux Mint MATE Sarah I don’t have that.
If you don’t know what I am on about, torrent a Linux systrem some time and you’ll see what I am talking about in transmission-gtk.
One awesome thing you could do as a new user is to install Infinality to improve how fonts appear.
Well I've just checked that and i can see its green, where did you copied theme files? I first had them at home folder but running gdebi and lightdm settings were rendered as white, so i put them in /usr/share and that solved the problem.
I installed from package; mint-y-theme and mint-y-icons @ http://packages.linuxmint.com. Interesting; I think I have some symbolic linking i need to do later.
Can anyone name the cursor in the image above it was the screenshot of @wolfman
mint-y is still a broken piece of trash but I am alright with it;
Other things:
Skydome:
Wallpaper:
Neuron from Digital Blasphemy, with some channel mixing to make it look the way it does
Stuff you don't see / which isn't obvious
Compiz 0.8
Patched NotifyOSD with the NotifyOSD configuration utility
RAVEfinity RAVE-X dark green full icons
Hi @asikroy.
the cursor is from the chameleon-cursor-theme set!
sudo apt-get update && sudo apt-get install chameleon-cursor-theme
Thanks a lot @wolfman
Back to Ubuntu Mate
Paper icon theme
GTK : Ambiance-Flat-Blue-Spring
plank settings here
plank theme here
Giving a try to albert instead of Synape
Compiz on.
Ready to go
thaks to the team
Hello,
yes, the Paper icon set is my favorite too. I use it with Arc theme.
But whats that for an yellow icon in the top left corner?
Hi !
This is Mate menu with a linux icon got somewhere around Google Internet ...
Very nice desktop! Very modern and clean.
Thank you so much
