Hello here is my problem:
Every time i start my Raspberry Pi 2 using Ubuntu Mate i get into the Emergency mode. I don`t have another computer running Ubuntu or Linux. Does somebody know what t do?
Thanks for your help.
I don't think its necessary to have linux installed on another computer. You can boot up the Live DVD on another computer and have a linux system thats good for one session.
I did get some forum hits:
Getting emergency mode screen on boot up every time
Skip / Disable / Block / Delete - Emergency Mode
And found a closed bug report:
I do not own a Pi so my help is limited. Good luck
Sorry i forgot to say that i cant write my sd card, because its write protected.
I don`t know how i can remove this protection.
Do you know how to remove the write protection? Otherwise I have to buy a new SD Card.
As far as I know, there is no hardware switch on the micro SD card to protect it.
You seem to have a card which is either fake or failed.
Good luck
Derek
In the past it worked, so i think it`s failed.
