GParted is a great tool for managing partitions. You’ll need to boot into the live session (via DVD/USB) as you cannot modify the partitions on a running system.
The tool can be found on the live session under Adminstration -> GParted. In there you can delete the Windows partition and then expand Ubuntu MATE to use the entire disk.
well the live cd works, got now 298,6 GB free on a partition but still struggling to get this unallocated free space completely for using for mine present linux
If you have no need for ANY data or files on the unused Windows area I suggest using it for your data. If it were me I would partition it ext4 (provided there’s no need for ANY Windows sharing) to use it for data. I suggest not trying to expand the partition used for Linux, but rather have it as an additional partition (or two) for storage. Using extra data partitions should be seemless because they will auto mount on boot.
If you follow the partition guide and you ever have to re-install, you can keep all your data intact by not formatting home using the "Something Else Method":
