Hi Wolfman, thanks for your reply… Done but it still keep crashing.
This is what I got when I launch it from terminal. may it help? Thx.
root@scarcio-ThinkPad-X220:~# synapse [INFO 19:17:45.342285] [synapse-main:266] Starting up... [INFO 19:17:45.457571] [synapse-main:208] Binding activation to <Control>space [INFO 19:17:45.491125] [view-base:251] Screen is composited. [INFO 19:17:45.492212] [controller:57] Using gtk-im-context-simple input method. [WARN 19:17:45.556046] [desktop-file-service:196] Unable to get exec for Evolution Data Server [WARN 19:17:45.561447] [desktop-file-service:196] Unable to create AppInfo for /usr/share/applications/vim.desktop [WARN 19:17:45.587828] [desktop-file-service:196] Unable to create AppInfo for /usr/share/applications/brasero-nautilus.desktop [WARN 19:17:45.611106] [ssh-plugin:114] /home/scarcio/.ssh/config: Error opening file: No such file or directory [INFO 19:17:45.613287] [hybrid-search-plugin:179] keeps in cache now 0 file names
How come you're running as root? Things will start to misbehave when root starts changing permissions in your home directory, which may be why it's not running normally.
Your terminal output doesn't seem to give any indication of a crash, just some warnings -- which you could disable all plug-ins and try each one. Did Synapse quit or is it working at this point? We need the terminal output of the crash to better assist.
@lah7 you are right… sorry. Thanks for letting me know.
This is the output running as user (no root). Tried to type something but it crashed immediately - the output below is with all the default plugins enabled.
scarcio@scarcio-ThinkPad-X220:~$ synapse [INFO 20:06:54.447111] [synapse-main:266] Starting up... [INFO 20:06:54.563764] [synapse-main:208] Binding activation to <Control>space [INFO 20:06:54.592112] [view-base:251] Screen is composited. [INFO 20:06:54.593014] [controller:57] Using xim input method. [WARN 20:06:54.646638] [desktop-file-service:196] Unable to create AppInfo for /usr/share/mate/applications/metacity-no-composite.desktop [WARN 20:06:54.648372] [desktop-file-service:196] Unable to create AppInfo for /usr/share/mate/applications/kde-Kantiword-Installer.desktop [WARN 20:06:54.656142] [desktop-file-service:196] Unable to get exec for Evolution Data Server [WARN 20:06:54.662415] [desktop-file-service:196] Unable to create AppInfo for /usr/share/applications/vim.desktop [WARN 20:06:54.690915] [desktop-file-service:196] Unable to create AppInfo for /usr/share/applications/brasero-nautilus.desktop [INFO 20:06:54.700901] [gnome-session-plugin:158] org.gnome.SessionManager is available [WARN 20:06:54.719372] [ssh-plugin:114] /home/scarcio/.ssh/config: Error opening file: No such file or directory [INFO 20:06:54.723332] [hybrid-search-plugin:179] keeps in cache now 0 file names Segmentation fault (core dumped)
I’ve disabled all the plugins available - see the output below. Again, as soon as I type something, it crashes immediately.
scarcio@scarcio-ThinkPad-X220:~$ synapse [INFO 20:21:51.992010] [synapse-main:266] Starting up... [INFO 20:21:52.145244] [synapse-main:208] Binding activation to <Control>space [INFO 20:21:52.182048] [view-base:251] Screen is composited. [INFO 20:21:52.183186] [controller:57] Using xim input method. [WARN 20:21:52.242103] [desktop-file-service:196] Unable to create AppInfo for /usr/share/mate/applications/metacity-no-composite.desktop [WARN 20:21:52.243462] [desktop-file-service:196] Unable to create AppInfo for /usr/share/mate/applications/kde-Kantiword-Installer.desktop [WARN 20:21:52.250832] [desktop-file-service:196] Unable to get exec for Evolution Data Server [WARN 20:21:52.256222] [desktop-file-service:196] Unable to create AppInfo for /usr/share/applications/vim.desktop [WARN 20:21:52.282483] [desktop-file-service:196] Unable to create AppInfo for /usr/share/applications/brasero-nautilus.desktop [INFO 20:21:52.292073] [gnome-session-plugin:158] org.gnome.SessionManager is available Segmentation fault (core dumped) scarcio@scarcio-ThinkPad-X220:~$
Please let me know if I can try with something else. Thx.
The solution in both reports is to run Synapse like this:
GTK_IM_MODULE='' synapse
If this fixes it, you can update the command in the Main Menu editor tool (System → Preferences → Look and Feel) for when it is launched via the Applications menu and/or in Start-up Applications (System → Preferences → Personal) so it applies at start-up.
Thank you very much !
Synapse use to work well during the beta steps, but since i did clean install from stable release, it crashed all time.
This fixed the bug !!!
Nice evening …
Since a few days ago synapse also crashes on my laptop, the temporally fix above mentioned worked for me. But it’s only a patch, so I’ve decided to try Albert:
I like it, works really impressive, and with the arc theme fits very well with my set up. Only one “issue”: In my laptop Albert uses near from 100mb of RAM. You can install from the Webupd8’s PPA:
