We are preparing Ubuntu MATE 19.04 (Disco Dingo) for distribution on April 18th, 2018 With this Beta pre-release, you can see what we are trying out in preparation for our next (stable) version.
Letβs rip that band-aid off and get this over quickly. Ubuntu MATE 19.04 is shipping with MATE Desktop 1.20. Albeit, the latest maintaince release of MATE Desktop 1.20 with some of the bug fixes and new features from MATE Desktop 1.22 included. In fact, the version of MATE Desktop being shipped in 19.04 is derived from the same MATE packages that will feature in the upcoming Debian 10 (Buster) release.
You may be wondering why weβre not shipping MATE Desktop 1.22? The answer, stability. MATE Desktop 1.22 introduces some underlying API changes in core components and while all first party MATE Desktop applications are compatible with the changes and completely stable, some third party applications are not. Some third-party applications are big crashers now and weβve not been able to fix them in time.
So, we are playing it safe and sticking with MATE Desktop 1.20 and working with upstreams so we can land MATE Desktop 1.22 early in the Ubuntu MATE 19.10 development cycle.
MATE Dock Applet
MATE Dock Applet has been updated to 0.88 which introduces some new visual options, both based on the look of the Unity desktop. As can be seen in the screenshot above these can be used to make the Mutiny layout more closely mimic Unity 7.
Remote Desktop Awareness
Our MATE Desktop 1.20 packages ship with patches to support Remote Desktop Awareness (RDA). RDA makes MATE Desktop more aware of its execution context so that it behaves differently when run inside a remote desktop session compared to when running on local hardware. Different remote technology solutions support different features and they can now be queried from within MATE components. The inclusion of RDA offers the option to suspend your remote connection, supports folder sharing in Caja, MIME type bindings for SSHFS shares and allows session suspension via the MATE screensaver.
Learn more and get the downloads from the release notes:
It is strange that Minimal installation adds LibreOffice icon to the menu, but it does not function. It also does not start from terminal. I reported this previosly to launchpad as bug 1813538 .
MATE Welcome β Getting Started β Optional tasks: unable to install Deja Dup - reported this previously as bug 1813549 .
Full and minimal install problems:
MATE Welcome β Software: boutique does not show applications with βSorry, Welcome could not feature any software fot this category that is compatible on this system.β message. But it is expected, as 19.04 is not released yet.
MATE Welcome β Getting Started β Updates & Extras: it is impossible to install Blu-Ray and DVD Playback Support - shows errors about Release file on VLC's site: it "is not signed". Maybe temporarily issue.
MATE Welcome β Getting Started β Drivers, Printers: HPLIP is listed here, but does not show its menu in tray (reported previously as bug 1810745 ).
MATE Welcome β Browser Selection: the Brave Browser does not install, but it is expected.
Has the "indicator applet icon scaling issue" been solved as mentioned here? There's been an upstream report about it though; I've tested and found out that on vanilla MATE desktop like on Fedora MATE spin and Debian MATE this inconsistency doesn't happen...
I intend to give the beta a spin later this day...
We have the bug report here on MATE Desktop, but I've found that this doesn't happen on vanilla MATE like on Fedora or Debian. So is the issue specific to UM?
not affected themes - BlackMATE, BlueMenta, Blue-Submarine, GreenLaguna, Green-Submarine, High Contrast, High Contrast Inverse, Menta, TraditionalGreen, TraditionalOk.
See TraditionalOk as a good example:
Monospaced text in Pluma's (and Gedit's) drop-down menu started to appear in Ubuntu 17.04. So I have reported this as bug 1823550. But really it is caused by theming of GtkSourceView component (see bug 52 on GNOME GitLab).
The issue:
exists with the following themes - Ambiant-MATE, Ambiant-MATE-Dark, BlackMATE, GreenLaguna, Radiant-MATE, TraditionalGreen, TraditionalOk;
does not exist with BlueMenta, Blue-Submarine, Green-Submarine, High Contrast, High Contrast Inverse, Menta.
Yeah, this issue has bugged me for ages. We've tried a few times to track it down. Ubuntu MATE uses Indicators and other MATE distros do not. This bug is likely in mate-indicator-applet or libappindicator. Certainly an issue I really want to fix.
Thank you for putting in so much effort to dig into these issues! Really useful information, thank you! No promises these will get fixed in 19.04 but this certainly gives me what I need to investigate futher
I have tested Ubuntu MATE 19.04 minimal with latest updates and can say that that all previously discovered problems seems to be fixed:
LibreOffice icon is removed from minimal install (bug 1813538 is fixed);
Deja Dup installs normally from minimal install (bug 1813549 is fixed);
Software tab of MATE Welcome is filled with the software. I see all 123 applications from here (including Brave Browser, it is installable now).
The updated MATE Welcome (rev 291) does not want show its contents with virtualbox-guest-x11 (or virtualbox-guest-x11-hwe) installed in guest and 3D Acceleration enabled.
But it works with official VBoxGuestAdditions_5.1.38.iso. I'm not completely sure what is going on here, so we need confirmation from other users.
My VirtualBox 5.1.38 may be too old for this Ubuntu 19.04 release.
I'm ready to test final daily ISO image or beta2 (if any).
I hope that GTK3-related problems will be fixed in 19.10 or maybe in 20.04 LTS
