I hit erase entire disk and then It gets done with installing. But when it restarts. My laptop says it still doesn't have an OS.
Did you remove the USB stick or DVD when you restarted?. The make and model of your computer might help?. Are you a beginner?.
olek
3
Hi guys
I got a similar issue on a lenovo yoga 11.
Did you done some bios configuration ? Are you on secure boot ? EFI or legacy ?
Hi TER,
boot from the Live USB/DVD and run Gparted to see what your partition layout is like!.
See the partition guide which may help?.
