Hello All,
I have upgrade my laptop from MATE 20.04 LTS to 22.04 LTS of course it had some issue during the upgrade. First, The Welcome/Software boutique will not start either through the menu or CLI, so I uninstalled via the CLI, when I tried to reinstalled it failed and I received an error that keeps popping up everywhere. I get this error during an install for the Welcome program, updating the system via CLI, and the same failure happened during the Upgrade to 22.04 LTS.
See the error below:
Unpacking ubuntu-mate-welcome (18.10.0) ...
Setting up libreoffice-common (1:7.3.5-0ubuntu0.22.04.1) ...
rmdir: removing directory, '/usr/lib/libreoffice/share/registry'
rmdir: failed to remove '/usr/lib/libreoffice/share/registry': Directory not empty
dpkg: error processing package libreoffice-common (--configure):
installed libreoffice-common package post-installation script subprocess returned error exit status 1
Setting up ubuntu-mate-welcome (18.10.0) ...
dpkg: dependency problems prevent configuration of libreoffice-help-en-us:
libreoffice-help-en-us depends on libreoffice-common (>= 1:6.1.0~); however:
Package libreoffice-common is not configured yet.
libreoffice-help-en-us depends on libreoffice-l10n-en-us; however:
Package libreoffice-l10n-en-us is not installed.
Package libreoffice-common which provides libreoffice-l10n-en-us is not configured yet.No apport report written because the error message indicates its a followup error from a previous failure.
dpkg: error processing package libreoffice-help-en-us (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of libreoffice-help-common:
libreoffice-help-common depends on libreoffice-common; however:
Package libreoffice-common is not configured yet.dpkg: error processing package libreoffice-help-common (--configure):
Processing triggers for man-db (2.10.2-1) ...
Errors were encountered while processing:
libreoffice-common
libdvd-pkg: Checking orig.tar integrity...
/usr/src/libdvd-pkg/libdvdcss_1.4.3.orig.tar.bz2: OK
libdvd-pkg:apt-get check
failed, you may have broken packages. Aborting...
E: Sub-process /usr/bin/dpkg returned an error code (1)
I will post my system info below:
mike@mike-HP-EliteBook-Folio-9470m:~$ inxi -Fxz
System:
Kernel: 5.15.0-46-generic x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: MATE 1.26.0 Distro: Ubuntu 22.04.1 LTS (Jammy Jellyfish)
Machine:
Type: Laptop System: Hewlett-Packard product: HP EliteBook Folio 9470m
v: A1029D1102 serial: <superuser required>
Mobo: Hewlett-Packard model: 18DF v: KBC Version 62.19
serial: <superuser required> BIOS: Hewlett-Packard v: 68IBD Ver. F.69
date: 02/13/2018
Battery:
ID-1: BAT0 charge: 27.0 Wh (96.8%) condition: 27.9/27.9 Wh (100.0%)
volts: 16.3 min: 14.8 model: Hewlett-Packard Primary status: N/A
Device-1: hidpp_battery_0
model: Logitech Marathon Mouse/Performance Plus M705
charge: 55% (should be ignored) status: Discharging
CPU:
Info: dual core model: Intel Core i5-3427U bits: 64 type: MT MCP
arch: Ivy Bridge rev: 9 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 1143 high: 1787 min/max: 800/2800 cores: 1: 1787
2: 1190 3: 798 4: 798 bogomips: 18358
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
Device-1: Intel 3rd Gen Core processor Graphics vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0
Device-2: Cheng Uei Precision Industry (Foxlink) HP HD Webcam [Fixed]
type: USB driver: uvcvideo bus-ID: 1-1.3:4
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: modesetting
unloaded: fbdev,vesa gpu: i915 resolution: 1366x768~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 22.0.5 direct render: Yes
Audio:
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Sound Server-1: ALSA v: k5.15.0-46-generic running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: kernel port: 2080 bus-ID: 00:19.0
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
v: kernel bus-ID: 03:00.0
IF: wlo1 state: up mac: <filter>
IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
mac: <filter>
IF-ID-2: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Drives:
Local Storage: total: 476.94 GiB used: 426.15 GiB (89.4%)
ID-1: /dev/sda vendor: SanDisk model: SD6SB2M512G1022I size: 476.94 GiB
Partition:
ID-1: / size: 468.38 GiB used: 426.15 GiB (91.0%) fs: ext4 dev: /dev/sda1
Swap:
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) file: /swapfile
Sensors:
System Temperatures: cpu: 50.0 C mobo: 0.0 C
Fan Speeds (RPM): N/A
Info:
Processes: 359 Uptime: 4h 6m Memory: 15.49 GiB used: 7.38 GiB (47.6%)
Init: systemd runlevel: 5 Compilers: gcc: 11.2.0 Packages: 3457 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Thanks In Advance,
Mike
