I always have a tough time getting wine installed correctly and I am doing a fresh install on Ubuntu MATE and I get this error. I have no idea what I am doing wrong.
This is the link with the install instructions I am following.
Suggestions?
Suggestions?
According to this link:
The HTTP 304 Not Modified redirection response status code indicates that there is no need to retransmit the requested resources.
This response code is sent when the request is a conditional request with an If-Modified-Since header ( the -N option in wget in this case ) and the condition evaluates to 'false'. It confirms that the resource cached by the client is still valid and that the server would have sent a 200 OK response with the resource if the condition evaluated to 'true'.
You've already added the repository.
( If not, or if you want to unconditionally download and add it again,
don't use the -NP but only -P in you wget command and try again. )
Now you can start installing it by issuing:
sudo apt update && sudo apt install --install-recommends winehq-stable
Thanks for this... I assumed it was an error because when I run the next command, as you suggested, I get "Unable to locate package winehq-stable". I had to use staging and it worked.
However, I feel a bit silly that I did not look up the error code myself. It would have changed my original post.
Thanks again for the help.
Hi, @GeekBone ![]()
I don't use "Wine" - https://www.winehq.org/ . However - and to supplement the nice reply that @tkn has already given you in this topic - I remember that @radax05 published the following answer in another topic, 17 days ago (on 1st September 2024):
Let me quote here the relevant text concerning installing Wine, in Ubuntu MATE 24.04 LTS ("Noble Numbat"), from that @radax05's answer, in that other topic:
I had to re-install
- WineHQ - the "devel" version (required for Notepad++ and HeidiSQL) - the "stable" version did not install!
I hope this helps ![]()
Thanks Ric.
Interestingly, I read a post of yours yesterday where you were having problems installing MATE a while ago and just went back to windows. Glad you resolved it and thanks again for the information.
Hi again, @GeekBone
You wrote:
You're welcome ![]()
Hmm? You're definitely confusing me with someone else
I have several computers where I dual boot Ubuntu MATE 22.04 LTS ("Jammy Jellyfish") or Ubuntu MATE 24.04 LTS ("Noble Numbat") with Windows 10 or with Windows 11, but I definitely have NOT given up on Ubuntu MATE and there was never a time where I had problems installing Ubuntu MATE and just went back to Microsoft Windows ![]()
Ha! I think I need to work on my reading comprehension... or can I blame it on old age?
No worries, @GeekBone
Thanks for clearing that up! Indeed, in that other discussion topic - "Tried to install Mate but it stayed in try it mode" - @nearlysociable was having trouble installing Ubuntu MATE 24.04 LTS ("Noble Numbat") and I tried to help him in that topic but, unfortunately, my efforts were unsuccessful. Understandably, @nearlysociable - who was very nice in that discussion topic - ended up giving up and went back to Windows 10.
