Hi there,
I have got a Terratec Cinergy Hybrid Stick.
Does anybody know how to install it so I can watch TV with Kaffeine?
Thank you.
There you go!, I hope it helps. ![]()
Thank you.
Though the stick shows with lsusb it still does not work.
there are 3 Terratec models showing as supported here:
http://linuxtv.org/wiki/index.php/DVB-T_USB_Devices#Firmwares
Did you restart the PC with the device plugged in?, don't do that!, did you install the firmware package? (Ctrl + Alt + t to open the terminal):
sudo apt-get install linux-firmware-nonfree
Do you have the firmware on a Windows driver disk?:
If your DVB-T stick is not working because your firmware is not part of the package “linux-firmware-nonfree”, you may have to extract and copy the firmware file (not the folder but its contents) from your Windows USB device driver disk into “File System > lib > firmware” as root, you can simply copy & paste the file, to do this, open a terminal (Ctrl + Alt + t) or press “Alt + F2” and type the following command:
gksudo caja
(gksudo nautilus in Ubuntu)
Once you have copied the file, close your home folder and restart your PC without the DVB-T device being inserted, if you have an internal DVB-T card, then obviously; this doesn't matter, please also note that
this is only for digital TV reception and not analogue TV!.
Once your PC has booted you can insert your USB stick; then open a terminal and type "lsusb" to see if your stick is shown, if it is; then you are good to go and just need to scan for channels using me-tv or kaffeine. (This is assuming you have DVB-T reception in your area!).
If the stick is shown here does that mean it has found it in “linux-firmware-nonfree” ?
mandalamatrix@jorn-System:~$ lsusb
Bus 002 Device 003: ID 0ccd:00a5 TerraTec Electronic GmbH Cinergy Hybrid Stick
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 006: ID 05e3:0723 Genesys Logic, Inc. GL827L SD/MMC/MS Flash Card Reader
Bus 001 Device 005: ID 05dc:c75c Lexar Media, Inc.
Bus 001 Device 004: ID 046a:0100 Cherry GmbH
Bus 001 Device 003: ID 24ae:2000
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Yes it has been detected!, did you get it working in the meantime?. ![]()
I have rebooted without stick and then inserted it.
Still no recognition in Kaffeine
Auch Me-Tv findet keine Sender.
Open Kaffeine > Television > Configure Television, is there a device showing there?:
There I get
Zarlink ZL 10353 DVBT
No suitable device found
If I do a scan
Okay, that is good, make sure you have a picture like this!:
See this as you are a German speaker:
Thank you.
I will work through that.
Post back if you still have a problem!.
you can help the community if you like?:
I can not find my card
in the list
What do you get when you paste this command in the terminal?:
dmesg | grep DVB
mandalamatrix@jorn-System:~$ dmesg | grep DVB
[ 53.154354] DVB: registering new adapter (Trident TVMaster 6000 DVB-T)
[ 53.154358] usb 2-1.5: DVB: registering adapter 0 frontend 0 (Zarlink ZL10353 DVB-T)...
In your earlier post, it showed the above name, now it is showing the following, did you put it a different (new) device?:
No, same device. Maybe he recognizes it under that name?
Still Terratec:
That is possible, have you tried me-tv again in the meantime because the device seems to be working okay?.
