The OS is incredibly fast, modern and stable. I have had a blast using it for various tasks. The below are the problems I have run into and suggestions for improvements:
1)Installing an alternate file manager is a feat I am yet to achieve; don’t get me wrong, Caja is great but I would prefer to istall PCManFM and no matter what I do I can’t get ubuntu to recognize it as the default file manager. When I start it manually, it works though. I have scoured the internet for a solution and couldn’t fins one.
2)Getting the cursor of my choice to be consistent across applications proved impossible; for example, I went with the Arc_Dark theme with Breeze_Blue cursor and the cursor is almost never the blue ncursor I want but the stock one. Even if it does turn into the one I want, it will again be the stock cursor in chrome, qbittorent and other apps. It does work with Firefox though!
I recently changed the stock white cursor to the black one for a change of scenery, I had issues with a mix and match of apps as you described, but luckily, this solution works:
Providing your cursor theme is installed to /usr/share/icons/
Open the terminal (CTRL+ALT+T), and type in the exact name of the cursor as a variable:
CURSOR=DMZ-Black
Run these commands. As you’ve assigned CURSOR to a variable, it just makes it a little easier.
@Bednar What version of Ubuntu MATE are you running? The issue with selecting alternative preferred applications should be fixed in 15.10 and I’ve back ported the fix to the 15.04 PPA.
As for the cursor issue, I’ve seen this but only under Compiz. Can you confirm you’re running Compiz? The feedback from @lah7 is very useful, it indicates that MATE needs to proxy the cursor settings to the org.gnome gsettings tree. Please confirm if you’re using Compiz and I can provide a patch to upstream MATE or possibly Compiz.
As for a kernel version manager, I won’t be adding one. I’ve never understood why Mint are so scared of new kernels Perhaps because they work outside of the Ubuntu community and customise package settings in an unorthodox fashion using Mint Adjustments? In any case, I see no need for such a tool in Ubuntu MATE
1)Following your suggestions I have managed to fix the cursor inconsistency issue once and for all. And yes, it was compiz! I changed the manager to metacity and it works perfectly fine now after applying the above suggestions. However, the theme is acting up in places; I switched to vertex dark with Mate-Faenza-Dark and have two issues. One is that the text in Caja is in black instead of white:
2)After upgrading Mate using the PPA Wimpy mentioned in his post, I also got PCManFM to somewhat work, but unfortunately variety wouldn't work with it so I got back to Caja for now. NB I also had to change required components under session in dconf from caja to PCManFM, but it worked.
UM is a fantastic system; I just wish it was more noob friendly!
3)AS for 3, I understand. There doesn't seem ( I am a newbie, so feel free to prove me wrong) to be a way of figuring out what kernels you have available on your machine. I always use the latest stable, now 4.1.4 and would like to purge the rest - GUI would be nice
Does the trick all the time. Can free up hundreds of MBs too if many still remain.
Always take caution removing old kernels, and double check the packages being removed are actually kernel packages (I've not had a problem with the command above).
@Bednar@Wimpy To change the default File Manager, you could try using xdg-mime to change the application that is associated with the MIME type inode/directory by default.
