I installed the Haskell platform then had some problems. The main issue was that I would get the following error message whenever I would start terminal:
Error: 0: couldn’t open source file <ghc-7.10.3>
ghc-7.10.3: No such file or directory
bash: warning: here-document at line 119 delimited by end-of-file (wanted `EOF’)
I have removed it from my laptop, but I’m still getting the error message in terminal. What should I do?
bash: fork: Cannot allocate memory
I’ve tried to remove it and it’s dependencies, I even tried to purge it and it’s dependencies, but all I get is the following message:
Having looked at the commands from the website again, I think this line might be correct now (I did tell you to enter them all as single commands so my fault there, sorry!):
Every time I tried to enter a sudo command, terminal would always give the exact same response:
The rest seemed to have no effect. I appreciate the help though.
At this point, I’m seriously considering doing a complete reinstall when Ubuntu 16.04 LTS comes out. Maybe even trying a different distro. What do you think?
How would I get it to format the hard drive and do a full installation instead of just upgrading. I’m afraid that if it simply upgrades, I might be stuck with the same issue.
And I’m very grateful for your help. I’m glad that there’s someone out there that’s willing share expertise with a newbie. In many cases, I’ve either been given the brush off or just felt ignored.
often the written word can cause more damage than the spoken!. Don’t give up and once you have re-installed at least 100 times; you’ll be able to do it blindfold!.
