Hi, Sorry if this isn’t the right place for trouble shooting, feel free to let me know where to go if it is wrong.
Ok, as the heading suggests, on start up my nuc has 2 ‘Starting Caja’ instances appearing every second in the lower panel.
No visible cursor, but the ‘cursor’ is there but invisible so I can open menus but no windows open when I click them. Even my favourite Tilda won’t open with F12, so apparently no command line option
Now I admit I was fluffing about with customising themes, and wanted to go back to a default, so in my googling one suggestion was that I hit reset compiz in mate tweak, which I believed to be fairly harmless. That was the last thing I did before last shutdown
If I log in as guest, it is fine, so it is stuffed up settings, but how to change without gui or cli?
Any ideas to try?
